Nominet Help
CSNM-Carl
Hi...
Ours isnt working... we have tried the commands as above and keep getting back "you need a passphrase to unlock secret key for user: <OUR TAG NAME> 2048 bit RSA key" Although password in correct... if we type password in wrong it gives us: same as above plus "no default secret key: bad passphrase"
Any suggestions?
Dale
  • Replies 53
  • Created
  • Last Reply
Top Posters In This Topic
create a file in the nominet/tmp/ folder called nominettest.txt , make sure there are no *.asc files in the folder and type:
gpg --no-tty --passphrase-fd 0 --clearsign ./tmp/nominettest.txt
it will then wait for you to type the passphrase
if that returns an error/fails then there's not a lot I can suggest except your gpg installation/keyring are not setup correctly, delete them, install again and work through the gpp website
Hi Rob,
The gpg --no-tty --passphrase-fd 0 --clearsign ./tmp/nominettest.txt works fine. I have changed the email address to my email address so I can check the output (and so it doesnt renew domain names) and still not getting an email from the system. Its using SMTP to send the emails (or should be) and should authenticate against our primary exchange server... other emails are sending from whmcs ok so not sure why these ones are not.
Any help would be much appreciated.
Dale
hmmm.... works with root user but doesnt work with whmcs user?
gpg: failed to create temporary file `/var/www//.gnupg/.#lk0x81168c8.cayote.7294': Permission denied
gpg: keyblock resource `/var/www//.gnupg/secring.gpg': general error
gpg: failed to create temporary file `/var/www//.gnupg/.#lk0x8117930.cayote.7294': Permission denied
gpg: keyblock resource `/var/www//.gnupg/pubring.gpg': general error
gpg: no default secret key: secret key not available
gpg: nominettest.txt: clearsign failed: secret key not available
So how do I attribute rights for access to keys for the whmcs user in gpg?
sorted it...
Had to:
create a directory under var/www//.gnupg
copy the secring and pubring generated under the main user account to this location
change the owner of the secring and pubring to whmcsadmin
then run the test again and it work....
D :)
Right... ok...
So I no have got the:
echo <oursecret> | gpg --no-tty --passphrase-fd 0 --clearsign nominettest.txt
to work.... from the whmcsadmin user... but still when I hit the nominet renew button its not working.. any more suggestions?
Thanks
Dale
Right... ok...
Set the email address for the plugin to yours and look at the generated mails
Did you send the test signed list request to nominet to check it was signed correctly ?
  • 1 month later...
Need to join the 'it isn't working for me' group :(
I have run
echo {passphrase} | gpg --no-tty --passphrase-fd 0 --clearsign ./tmp/nominettest.txt
I get an asc file - which I have sent to Nominet and got back the list of domains.
That all seems fine :)
However my emails remain unsigned :(
My path is set to
/var/www/vhosts/isdoo.com/.gnupg
which is correct.
I ran the above script from the user isdoo - so as far as I can tell everything is working, yet the emails are coming through to me as unsigned when tested within whmcs.
I have PGP Sign the Email ticked as well.
If I try and do a renew for example - I get no errors in whmcs apart from the email to me is unsigned (I have set me as recipient whilst testing)
Have I missed something?
what user is running the webserver app ?
can that user access gpg ?
is the .gnupg file in the right place for the webserevr user ?
have you worked through the gpg tutoral both from ssh and within webpages ?
to-date not a single one of these issues has been a problem with WHMCS or the module :P
as far as I can tell yes to everything - I logged in via ssh with the user isdoo
I then ran the test with that user and got the signed email ok.
So as far as I can tell everything is in the correct place and has the correct permissions.
I can't find any errors - but obviously I have one somewhere
isdoo 8022 0.0 0.0 3976 616 pts/0 S+ 18:50 0:00 \_ grep httpd
root 3508 0.0 1.2 44140 25616 ? Ss Oct09 0:11 /usr/sbin/httpd
root 6545 0.0 0.7 32884 15728 ? S Oct17 0:00 \_ /usr/sbin/httpd
apache 6547 0.0 0.7 33200 15796 ? S Oct17 0:00 \_ /usr/sbin/httpd
apache 21269 0.9 1.4 53404 29724 ? S 17:30 0:44 \_ /usr/sbin/httpd
apache 22941 0.8 1.4 53340 29444 ? S 17:38 0:38 \_ /usr/sbin/httpd
apache 23954 0.9 1.4 54820 30832 ? S 17:42 0:37 \_ /usr/sbin/httpd
apache 24021 0.9 1.4 53148 29144 ? S 17:42 0:36 \_ /usr/sbin/httpd
apache 24064 0.8 1.4 53236 29232 ? S 17:43 0:36 \_ /usr/sbin/httpd
apache 24068 0.9 1.5 54832 31272 ? S 17:43 0:37 \_ /usr/sbin/httpd
apache 24129 0.8 1.4 54600 31120 ? S 17:43 0:33 \_ /usr/sbin/httpd
apache 25622 0.8 1.5 55092 31192 ? S 17:47 0:34 \_ /usr/sbin/httpd
apache 27951 0.8 1.4 53972 30352 ? S 17:56 0:28 \_ /usr/sbin/httpd
apache 28955 0.8 1.3 53116 28860 ? S 17:59 0:24 \_ /usr/sbin/httpd
apache 29080 0.8 1.4 53156 29132 ? S 18:00 0:26 \_ /usr/sbin/httpd
apache 29242 0.8 1.4 54524 31080 ? S 18:00 0:25 \_ /usr/sbin/httpd
apache 29761 0.9 1.3 53064 28824 ? S 18:02 0:27 \_ /usr/sbin/httpd
apache 30469 0.8 1.3 53168 28836 ? R 18:05 0:23 \_ /usr/sbin/httpd
apache 3236 0.9 1.3 51660 27468 ? S 18:30 0:11 \_ /usr/sbin/httpd
apache 3304 0.8 1.3 52988 28580 ? S 18:30 0:10 \_ /usr/sbin/httpd
apache 3305 0.9 1.3 53048 28636 ? S 18:30 0:11 \_ /usr/sbin/httpd
apache 5855 0.9 1.3 52676 28252 ? S 18:41 0:05 \_ /usr/sbin/httpd
apache 7603 0.9 1.1 46936 24160 ? S 18:47 0:01 \_ /usr/sbin/httpd
apache 7611 0.8 1.3 52988 28492 ? S 18:47 0:01 \_ /usr/sbin/httpd
I assume it is apache - I ran that from the ssh login of isdoo.
I am really not sure what I am seeing - sorry :(
So if it is apache (all the files are owned by isdoo - so assumed it was isdoo and not apache) what do I need to do?
  • 1 month later...
I'm just setting this up - here is what I've done...
1. Uploaded pubring.pkr and secring.skr to the home/username/.gnupg directory for the user running whmcs.
This is a cpanel server and I know gnupg is installed correctly and working because I'm using it in another account with a different script.
2. Renamed these files with the gpg extension.
3. Ensured the permissions are set correctly on these files - owned by the user and chmod 0700
We are using suphp on this server so PHP is running as the owner of the files.
4. Configured the Nominet module in whmcs and set my email address for testing. I'm not using a passphrase on this currently so I didnt enter anythign in that field.
5. placed an order and attempted to register
The result I get is a totally blank email.
I have also done the following...
1. Removed the public and private keys form the home/username/.gnupg directory and added them in cpanel using the import option by pasting from the .asc file. I note that the gpg files are created correctly.
This produces the same result when I test it.
Does anyone have any ideas why this might not be working ? I'm scratching my head atm.
I ran the test...
echo | gpg --no-tty --passphrase-fd 0 --clearsign ./tmp/test.txt
And it correctly signed the file, leaving behind a test.txt.asc file containing the signed test text i had put in there.
So why is it coming up as a blank email when I send a test to myself via whmcs?
you have to have a passphrase
then you have a permisison problem - probably on the ./tmp/folder in the nominet module
  • 2 months later...
Howdy All.
Having problems myself with this.
The server commands from whmcs are being run as apache.
TMP file is 0777
gpug is in right place but is owned by siteadmin. I've tried various different users including apache and have also moved it into the public html directory
Email gets sent fine but is never signed. Driving me crazy! I know is isn't a WHMCS issue but I can't work it out for the life of me.
I can run the echo line fine from the command line which suggests a permission error for the apache user. Any pointer as to where to start looking?
Cheers,
Adam
