Downloadable product files problem
anglian
I have my 'downloads' directory set as $downloads_dir = '/home/username/downloads/'; and chmod 777
I am, however unable to add files to a product successfully.
The files show in the available files and selected files windows but are not in the downloads folder and when a client clicks on the download link gets a file not found error.
I would appreciate some guidance to get this issue resolved.
Also, how is it possible to remove files from a product?
Thanks
  • WHMCS Product Manager
Common problems for attachments not attaching correctly to tickets/client files are the path to the attachment directory being incorrect in configuration.php, the attachment directory not being writeable or something else on the server preventing the upload, maybe a PHP disabled function?
