tomb Posted April 2, 2012 Share Posted April 2, 2012 Does WHMCS affiliates for one-time and recurring items? How can I restrict affiliate earnings to recurring invoices (hosting plans + domains) only? 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted April 3, 2012 Share Posted April 3, 2012 You can set the affiliate amount on a product-by-product basis - just turn it off for the products you're not offering comissions on 0 Quote Link to comment Share on other sites More sharing options...
tomb Posted April 3, 2012 Author Share Posted April 3, 2012 thank you for your reply. Sorry I wasn't not clear enough. What happens to services that are not listed under Products/Services? When I manually create an invoice, does WHMCS always apply the affiliate earning percentage to ALL invoices for the specific client? 0 Quote Link to comment Share on other sites More sharing options...
zomex Posted April 3, 2012 Share Posted April 3, 2012 thank you for your reply. Sorry I wasn't not clear enough. What happens to services that are not listed under Products/Services? When I manually create an invoice, does WHMCS always apply the affiliate earning percentage to ALL invoices for the specific client? No, it doesn't at this time unfortunately. But you could always work out the commission manually and apply it to their affiliates account. Having said that it would be hard to monitor who sent which customer unless they ordered a product that is already setup with a commission. 0 Quote Link to comment Share on other sites More sharing options...
tomb Posted April 4, 2012 Author Share Posted April 4, 2012 Thanks. Actually this is what I was looking for. ;-) 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted April 6, 2012 Share Posted April 6, 2012 When I manually create an invoice There's no affiliate commissions on manual invoices, only on "products" invoice items. 0 Quote Link to comment Share on other sites More sharing options...
