Date/time problem
brandom9
After update a server to a latest software (thru Custombuild/Directadmin), there is a problem with the date/time displayed. The date/time in WHMCS are not the same as the date/time displayed in the server.
In our server shows :
[root@server ~]# date
Fri Feb 17 04:49:58 MYT 2012
This is what shown in WHMCS:
Thursday, 16 February 2012, 20:50
I've tried to reboot he server, but still failed to fix it.
Pls help me.
Thanks
What do you have the system time (CMOS) set to? I wonder if WHMCS is picking that up rather than the OS time.
I think, the setting is correct. But I cannot re-check now.
Try to add the following line in configuration.php
date_default_timezone_set('Europe/Oslo');
You can see the TimeZones at the following URL:
http://php.net/manual/en/timezones.php
Your guidelines are working. It's OK now. Many thanks for you help
Thanks
