dmz Posted January 24, 2012 Share Posted January 24, 2012 Hello, Can you tell me please how the project management add-on works with clients? For example if I want a client to be able to login and view their project area comment on tasks upload file etc, can the add-on accommodate this? Regards 0 Quote Link to comment Share on other sites More sharing options...
0 WHMCS Product Manager WHMCS John Posted January 24, 2012 WHMCS Product Manager Share Posted January 24, 2012 Not at the current time: Updates will be forthcoming, with plans already in place to expand into the client area http://blog.whmcs.com/?t=44537 0 Quote Link to comment Share on other sites More sharing options...
0 Kevin Fick Posted January 28, 2012 Share Posted January 28, 2012 On the Project Management add-on, I take it from the docs that a client can work indirectly thru support tickets, with the client area page coming down the road. What I'm very interested in is will the new P.M. add-on work with a Vision support ticket system (configured/installed for that WHMCS of course) instead of the native internal one. Thanks. 0 Quote Link to comment Share on other sites More sharing options...
0 WHMCS Liam Posted February 1, 2012 Share Posted February 1, 2012 Yep exactly, projects can be associated with tickets, and so the idea is that you continue to use the ticketing system for all staff to client communication relating to projects. And a client side overview of projects will then be coming up in an update in due course. The tickets association can only work with the built in help desk though, not a third party one such as Vision. Regards, Liam 0 Quote Link to comment Share on other sites More sharing options...
0 crazyfish Posted February 2, 2012 Share Posted February 2, 2012 Is there an ETA on the client side updates? 0 Quote Link to comment Share on other sites More sharing options...
Question
dmz
Regards
4 answers to this question
