Resellerclub Advanced Management DNS Interface for WHMCS
We are pleased to announce the new version of our product R.A.M.D.I - Resellerclub Advanced Management DNS Interface!
Key Features
    Easy Install and Setup in minutes
    Customer friendly domain forwarding management interface
    Includes Easy Domain forwarding Interface into clientareadomaindetails.tpl. You can place the button anywhere
    New! Shows if domain is configured with the correct DNS setup required for the domain forwarding service and offers easy solutions
    New! Offers now a Button to change automatically to the required DNS servers for the domain forwarding service
    Domain forwarding interface checks if hosting exist to avoid service activation and "A record" setup
    Integration in "My Domains" and "My Products & Services " to offer dns managment for domains and webservices
    Manage Create Modify and Delete A, AAAA, CNAME, MX, NS, TXT and SRV Records
    SOA Record editable
    Pagination and sorting of all record types fully integrated
    Seamless integration into your Client Area domain details and product details page.
    Template and Style based on WHMCS "portal" design.
    WHMCS default template design available
    Language files available for English and Spanish. You can add your own languages by simply translating the main English file
    All error messages correctly interpreted and editable through the language file.
    User friendly and easy understandable DNS managment interface.
Screenshots, Free Trial and more informations available at our website http://www.resellerclub-mods.com/products/management-mods/ramdi.html
Best Regards,
Marco
hmmm... I am not sure if I have correctly understand what you mean.
The Resellerclub DNS management service requires their 4 DNS servers which you could setup as fully branded DNS servers with your domain or by using the partially branded DNS servers.
Could you please explain what you exactly need, may be with your own scenario in mind?
Regards,
Marco
  • 4 months later...
Hi All,
We have launched yesterday 27th April the new v3.1 version with Multi LogicBoxes Registrars Support.
No more barriers or limitations! Use all mods & modules for ResellerClub, Resell.biz (stargate) and Net Earth One simultaneously with the same Interface, the same Module, at the same time!
Regards,
Marco
  • 7 months later...
Hi All,
We have launched today a new update for Resellerclub Advanced Management Dns Interface (RAMDI) v3.2.1
Changelog
1-click Buttons for Google Apps - Your customers can now create the required A, MX and CNAME Records for Google Apps with the new 1-Click Google Apps buttons. This feature can be deactivated from the ResellerClubs Mods Console Addon v1.0.6 if you do not want expose these buttons.
Sort order by value Bug - The sort order feature by value was not working properly and has been fixed.
Search/Filter option Bug - The search record and reset search option was not working properly. This has been fixed
Overall code improvement - We have improved upon the complete code and optimized the interface. This has resulted in speed increase
Suggestions, feedback, constructive criticism, etc. etc is always welcome.
Regards and happy new year,
Marco
  • 1 month later...
Hi All,
We have launched today a new update for Resellerclub Advanced Management Dns Interface (RAMDI) v3.3.1
Changelog:
1-click Buttons for Google Apps - Your customers can now create also the required SRV and TXT(spf) Records for Google Apps with the new 1-Click Google Apps buttons.
CNAME Calendar - Creating CNAME records have been extended with the entry "calendar".
Domain Forwarding Check - The option to check if a domain has an active hosting account has been improved and extended. It now checks if the domain has an active SDH, MDH or RH hosting plan and prevents domain forwarding service activation.
Regards,
Marco
Hi All,
We have launched today the new version for our Management Mod RAMDI - ResellerClub Advanced Management Dns & Domainforwarding Interface.
Changelog
Ready for API Key - The new version v3.4.1 uses now only your unique API Key in place of your Reseller Password.
1-click Buttons for Google Apps - CNAME Records added for docs and sites.
More infos for installation and update can be found here: http://www.resellerclub-mods.com/en/products/management-mods/ramdi.html
Regards,
Marco
