filipeapsilva Posted November 4, 2011 Share Posted November 4, 2011 Hello I have WHMCS, which has an integration with Plesk when I get past the last record and click on the "Completar Pedido" the Apache my server stops running, and back in a few minutes to see the error occurs, you must follow the steps of the image: http://www.an7.com.br/fault-simulation/ for testing, access http://www.an7.com.br/central/cart.php?a=add&pid=9 (do not worry to conduct the test, this registration is not valid for anything) The point is that the problem began to occur suddenly worked normally before what might be happening? thank you 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted November 7, 2011 WHMCS Product Manager Share Posted November 7, 2011 Are you using Plesk 10? If so this thread might be relevant: http://www.webhostingtalk.com/showthread.php?t=1027068 0 Quote Link to comment Share on other sites More sharing options...
