Grissom Posted September 15, 2011 Share Posted September 15, 2011 Hi, while testing my installation and setup I noticed that I can't properly add additional products with the same domain another product would already be connected to. An example: I use Enom for domain reselling, ResellerClub for the hosting part and EnomSSL for SSL certs. After adding e.g. 2 hosting packages to the cart with different domains, I try to add a SSL cert with the same domain name as one of the already added hosting packages but all I see in the cart then is the SSL cert with the domain name and the other hosting package with the other domain name - adding the SSL cert to the cart removed the hosting package with the same domain name. Can anyone confirm this behaviour? Best regards, Chris 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted September 15, 2011 WHMCS Product Manager Share Posted September 15, 2011 SSL certs don't need a domain when ordering, it's defined in the CSR which you submit later, so untick the "Require Domain" option in the SSL product configuration. 0 Quote Link to comment Share on other sites More sharing options...
Grissom Posted September 16, 2011 Author Share Posted September 16, 2011 Ah, ok...that makes sense. Thanks a bunch! Chris 0 Quote Link to comment Share on other sites More sharing options...
