steemer473 Posted August 26, 2011 Share Posted August 26, 2011 I just wanted to confirm the Credit Card Charging Settings under the Automation settings of WHMCS. Is the default setting is that whmcs will attempt to charge a clients card every day for the number of weeks you specify? Or willl it only charge once for the specified number of weeks you specify? 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted August 26, 2011 Administrators Share Posted August 26, 2011 The default settings will attempt the client's card every day. For more info refer to http://docs.whmcs.com/Automation_Settings#Credit_Card_Charging_Settings 0 Quote Link to comment Share on other sites More sharing options...
