kindoo Posted July 25, 2011 Share Posted July 25, 2011 After trying to install WHMS following the instructions i still get an error "Could not connect to the database etc.." Any help would be usefull Thank you. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted July 25, 2011 WHMCS Product Manager Share Posted July 25, 2011 You'll need to check with your server admin/hosting provider that the database info you're using is correct. 0 Quote Link to comment Share on other sites More sharing options...
robb3369 Posted July 25, 2011 Share Posted July 25, 2011 Check the configuration.php file for these four lines and make sure the values are correct: $db_host $db_username $db_password $db_name 0 Quote Link to comment Share on other sites More sharing options...
