ysar68 Posted March 2, 2011 Share Posted March 2, 2011 I upgrade my whmcs in version 4.4.2 , with all the steps describe in instructions , after i finish with the upgrade and i erase the install folder when i go in admin folder and comes out the login for admin i give my admin and pass but returns again in the same screen login area and this is happening all the time , with few word does not allow me to login in admin area! what is this problem , and how i can fix it propably? Thank you 0 Quote Link to comment Share on other sites More sharing options...
Administrators WHMCS John Posted March 2, 2011 Administrators Share Posted March 2, 2011 Are you able to login with the "Remember Me" checkbox ticked? If so this suggests an issue with PHP sessions on your server. 0 Quote Link to comment Share on other sites More sharing options...
interfasys Posted March 3, 2011 Share Posted March 3, 2011 We had a similar problem. Impossible to login with Chrome, but worked with FF4. So it seems it isn't a server side issue, but could come from a plugin. 0 Quote Link to comment Share on other sites More sharing options...
ysar68 Posted March 3, 2011 Author Share Posted March 3, 2011 the same when i check the "remember me" returns in the login admin 0 Quote Link to comment Share on other sites More sharing options...
interfasys Posted March 3, 2011 Share Posted March 3, 2011 Did you try switching to a non-SSL URL? 0 Quote Link to comment Share on other sites More sharing options...
