(iTD) Posted January 19, 2011 Share Posted January 19, 2011 I am using Configurable Options to allow clients to add disk space, bandwidth ..etc. to their hosting accounts. Using Configurable Options is preferred in this case to using Addons as I would like the additional services to invoice annually with their hosting (and not separately on the anniversary of the addition of new services to their account). Oh, and yes, I bill annually for hosting. The Situation: * The client's hosting is not due until July 23rd ... It is now January 19th. * The client ordered more disk space. * I logged into admin, went to the client's Products/Services tab and selected the Configurable Option to add the disk space to their account (no problem) * I clicked the option to Auto Recalculate on Save - and indeed the new total is correct for their next billing cycle. The Problem: I need to submit a pro-rated invoice for the time period between now and their next hosting renewal in July. Is this an option? Or must I manually do the math and submit a separate invoice? Thanks! --Kevin 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted January 19, 2011 WHMCS Product Manager Share Posted January 19, 2011 If you're running 4.4.1 or later click the "Create Upgrade/Downgrade Order" link instead and WHMCS will generate a pro-rated invoice. If you're running an earlier version then you'll need to create the invoice manually. 0 Quote Link to comment Share on other sites More sharing options...
(iTD) Posted January 19, 2011 Author Share Posted January 19, 2011 Perfect John! Thanks - that did the trick and was exactly what I was looking for. Question: I notice after running the "Create Upgrade/Downgrade Order" that the additional disk space (configurable option) was not added to the client's account. * Will it be added when the invoice is paid? * or do I need to manually add the disk space and recalculate the new total? Thanks! --Kevin 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted January 19, 2011 WHMCS Product Manager Share Posted January 19, 2011 It will be upgraded automatically once the invoice is paid, as described in our documentation: http://docs.whmcs.com/Products_Management#Upgrades.2FDowngrades 0 Quote Link to comment Share on other sites More sharing options...
