mylove4life Posted December 15, 2010 Share Posted December 15, 2010 Hi all, I get an error when logging into the cart from the Existing Client Login screen, if I enter my info it directs to /cart with no .php or anything. What should it be directing to? On 4.4.1 with all the other updates. Thanks 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted December 16, 2010 WHMCS Product Manager Share Posted December 16, 2010 Have you added anything to your .htaccess file that could be causing this? 0 Quote Link to comment Share on other sites More sharing options...
mylove4life Posted December 16, 2010 Author Share Posted December 16, 2010 nope, nothing added to it. 0 Quote Link to comment Share on other sites More sharing options...
Kennethav Posted January 13, 2011 Share Posted January 13, 2011 I'm also experiencing this in 4.4.1 with no changes to the .htaccess file. When I log in from cart.php?a=login, the form is posted to dologin.php?goto=cart. This script redirects to /cart that doesn't exists. 0 Quote Link to comment Share on other sites More sharing options...
pbnet Posted July 27, 2011 Share Posted July 27, 2011 Same here... hitting a 404 with dologin.php?goto=cart 0 Quote Link to comment Share on other sites More sharing options...
