DMDiller Posted October 28, 2010 Share Posted October 28, 2010 I am trying to get my ResellOne account to work correctly and am encountering some issues with domains and such. It's not registering things correctly which is one issue, but the second issue is a bit more annoying - whenever I go to the Domains tab of a clients page that has a domain that is registered through my WHMCS, it doesn't show anything properly - it just shows a few things (missing some options) on a white background. I have narrowed it down to ResellOne, since if I have it set to Email or None then everything displays fine. Check out the attachment to see how it displays... It should also be noted that I have not changed ANY of the code or anything at all - first time using WHMCS, first time trying this out, etc. I tried to submit a support ticket but it wasn't created because the email that I used isn't 'on file' here (likely because my copy of WHMCS is registered through my host instead of directly by me). Any help would be appreciated! 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted October 29, 2010 WHMCS Product Manager Share Posted October 29, 2010 http://forum.whmcs.com/showthread.php?t=21317 0 Quote Link to comment Share on other sites More sharing options...
DMDiller Posted November 2, 2010 Author Share Posted November 2, 2010 Still confused as to why I am getting the following errors: Warning: main(/home/touchsto/public_html/client/modules/registrars/resellone/../opensrs/PEAR/PEAR.php) [function.main]: failed to open stream: No such file or directory in /home/touchsto/public_html/client/modules/registrars/resellone/resellone_base.php on line 0 Fatal error: main() [function.require]: Failed opening required '/home/touchsto/public_html/client/modules/registrars/resellone/../opensrs/PEAR/PEAR.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/touchsto/public_html/client/modules/registrars/resellone/resellone_base.php on line 0 Mostly confused about the /../ part. I know that all my information is accurate, but when I generate a new Private Key at ResellOne I do get a message that says: Cut and paste the private key listed below into your OpenSRS.conf file: (private key) Attention: Please note that you must upgrade your client configuration file immediately with the new private key. Until your configuration file is updated, your cgis will NOT work. Any help would be appreciated. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted November 3, 2010 WHMCS Product Manager Share Posted November 3, 2010 Please ensure that you have the files available @ http://wiki.whmcs.com/OpenSRS#Additional_Registrar_Module_Files_Requirement uploaded to your installation and then retry this. 0 Quote Link to comment Share on other sites More sharing options...
