whitewizard Posted October 14, 2010 Share Posted October 14, 2010 I just created two forwarders in the pipe to a program I write public_html/whmcs/pipe/pipe.php and I created a cron function like this | php -q /home/tarr/public_html/whmcs/pipe/pipe.php every minute. But in the support ticket log I have this message every time that the cron runs: Department Not Found. No more explanations about the error. I´m very confused about it. Thanks for your support, Diego 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted October 14, 2010 WHMCS Product Manager Share Posted October 14, 2010 You're confusing the two different methods. If using an email forwarder with the pipe.php file you don't need to create a cron. 0 Quote Link to comment Share on other sites More sharing options...
whitewizard Posted October 14, 2010 Author Share Posted October 14, 2010 Thanks Jhon, yes I´m doing a stupid mistake. 0 Quote Link to comment Share on other sites More sharing options...
