SSL Registration Problem
worsin
I use Enom for SSL certs and until last patch it all worked fine. Now when i go to register the SSL Cert with Enom i get the following.
Module Command Error
Bad User name or Password
Please tell me what else i need to provide to best resolve this.
Also to be clear the username and password are correct.
  • WHMCS Product Manager
Technical Issues and Questions
If you are experiencing problems with your WHMCS system, then post here for assistance from other forum users.
If you'd like a guaranteed response from us, please open a support ticket. Your eNom login details need to be entered on the product's module settings tab for SSL certs.
