Transparent order process
webboy
Hi all just another questions
Would it be possible to have a order button from another domain
Eg i wish to have the order button on 3 domains, but would like the domain name to look transparent after the user clicks to order by masking the the url , not reveal the primary instillation of the whmcs
Can this be done ?
ah sorry meaning
(masking in the url like a redirect) or i frame
So if a order button was on domain A or Domain B and clciked on by a customer this would go to WHMCS but would have domain name will be still in the the header of the browser no the the new location of the WHMCS install
(hence the word transparent)
What do you mean by ? How can you make your domain transparent ;)
I think it's not possible. Because when visitor buy something then they have to go at
http://www.yourdomain-A.com/cart.php'>http://www.yourdomain-A.com/cart.php
You can't just keep http://www.yourdomain-A.com domain during whole checkout process.
As far as i know WHMCS .php files doesn't work from external domain. Let's see what others say.......
Thanks for that
I wish use the back end system controlling all my websites and not have a multiple installations of WHCMS, I just saw a post with the iframe way which could work. But anymore suggestion would be nice
Therese
If you have multiple stores / shopping / hosting websites then the best thing you can do is to buy a separate domain for just checkout process for all these.
All you clients can have same billing and management system and it will be alot easier for you to manage....
i see what your saying here bit would look a bit odd when a person goes to oder from http://www.mystore.com/check out them gets redirected to http://www.the billing center.com / it should be transparent like they never left the domain
QUOTE=Slum Host;156762]If you have multiple stores / shopping / hosting websites then the best thing you can do is to buy a separate domain for just checkout process for all these.
