Greenix Posted June 9, 2010 Share Posted June 9, 2010 I'm sure this can be done, and I can use some advice if it has already. I have set up two products and need to have them both ordered at the same time ( one link) and would like to know how to do this? I don't think addons will work in this case as these are 2 different products. Example: Marketing Package, but I want to include Hosting. So these have to be treated like 2 separate products but need to be ordered at one time. Any suggestions, advice - I'm still a little new with the software so your help is greatly appreciated- Thanks -M 0 Quote Link to comment Share on other sites More sharing options...
meeven Posted September 17, 2010 Share Posted September 17, 2010 I am looking for the same feature too. In my case, I have separated a typical hosting package into components from different providers. For example, the DNS hosting is from a different provider, email hosting from another and spam filtering from another. And, in WHMCS, each is a separate product. So, to offer a typical hosting package, I need to combine several different products into one and present it in one package. Is this possible in WHMCS or will it require custom coding? Or, will it be impossible even with custom coding? 0 Quote Link to comment Share on other sites More sharing options...
