Affiliate System - How does it work ?
Derek
Hi there,
I noticed you can disable it from being recurring to one time payout (which is what we want since we do 100% credit). Beside that it has the 0.00 if we set that to 100.00 and check mark Percentage that gives them a 1 time payout of 100% of the purchase the refered correct ?
