semaj Posted March 12, 2010 Share Posted March 12, 2010 hello people av followed the custom instructions to making the page, av tried adding html code and it seems to place the "Powered by WHMCompleteSolution" at the top of the page insteed of at the bottom where ist ment to be. this is all i've added the the .tpl file <table align="left" cellpadding="0" cellspacing="2" id="login"> <img src="images/shoutcast-hosting-logo.gif" width="250" height="95" alt="Milford Sound in New Zealand" /> <form action="http://www.bluelayershoutcast.com/?page=login" method="POST"> <td>Username: <input name="username" type="text" /><br> Password: <input name="user_password" type="password" /></td> <td rowspan="2"><br><input type="image" name="login_submit" src="./castcontrol/theme/CASTcontrol 143/images/btn_go.jpg" alt="Login" border="0" /></a></td> </form> Dose anyone no where am going wrong its showing up fine but the "Powered by WHMCompleteSolution" just dos'nt seem to stay where its ment to. any feed back that could help me is worth a try. Thanks 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted March 12, 2010 WHMCS Product Manager Share Posted March 12, 2010 The Powered By line is automatically inserted between the end of the page template and footer.tp, so you just need to modify your layout around this. http://wiki.whmcs.com/Client_Area_Template_Files 0 Quote Link to comment Share on other sites More sharing options...
semaj Posted March 12, 2010 Author Share Posted March 12, 2010 The Powered By line is automatically inserted between the end of the page template and footer.tp, so you just need to modify your layout around this. http://wiki.whmcs.com/Client_Area_Template_Files how do i define the end of the page, its fine if i dont add any code but soon as i add any code it messes up and put powered by line above the code. 0 Quote Link to comment Share on other sites More sharing options...
