isixhosting Posted February 2, 2010 Share Posted February 2, 2010 Hi, is it possible to enable/disable affiliates for individual products? I have products which I don't want to be included into the affiliate program. Thanks 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted February 2, 2010 WHMCS Product Manager Share Posted February 2, 2010 Yes, you could set a 0 commission for the products you want to exclude on the Other tab in the product config area. 0 Quote Link to comment Share on other sites More sharing options...
isixhosting Posted February 2, 2010 Author Share Posted February 2, 2010 (edited) Ok, but I have to choose "Percentage" or "Fixed Amount" because if default then it would take the settings from the Affiliate tab in the General settings, right? Or what is the option for in the Affiliate tab under General "Affiliate Earning Percentage"? Edited February 2, 2010 by indy0077 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted February 2, 2010 WHMCS Product Manager Share Posted February 2, 2010 Ok, but I have to choose "Percentage" or "Fixed Amount" because if default then it would take the settings from the Affiliate tab in the General settings, right?That's correct. 0 Quote Link to comment Share on other sites More sharing options...
uriel Posted March 14, 2010 Share Posted March 14, 2010 (edited) Hi Guys, The way I understand this - I have set the General Tab percentage to 6%. Now what you are saying is it will be over ridden on a product level if I don't enter 6% per product ? Edited March 14, 2010 by uriel email notification 0 Quote Link to comment Share on other sites More sharing options...
uriel Posted March 14, 2010 Share Posted March 14, 2010 mmmhhh I think I might have this figured out now - if Default is selected it would pick up what is entered under the General Tab. So to exclude a product select Percentage and leave it 0%. Am I right ? 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted March 15, 2010 WHMCS Product Manager Share Posted March 15, 2010 Yup, that should do the trick. 0 Quote Link to comment Share on other sites More sharing options...
uriel Posted March 15, 2010 Share Posted March 15, 2010 Thanx John 0 Quote Link to comment Share on other sites More sharing options...
