hostin4u Posted January 2, 2010 Share Posted January 2, 2010 I keep getting the error: Module Create Failed - Service ID: 6 - Error: (Curl Error) couldn't connect to host - code: 7 Can anyone shed some light on this problem? Many Thanks, Hostin4u 0 Quote Link to comment Share on other sites More sharing options...
HostHighway Posted January 3, 2010 Share Posted January 3, 2010 If your using cpanel/WHM make sure that your server type is placed on Cpanel, and that you've got your remote access key pasted in the Access Hash field of your server config correctly. 0 Quote Link to comment Share on other sites More sharing options...
HostHighway Posted January 3, 2010 Share Posted January 3, 2010 Are you using cpanel/WHM ? if so make sure your Type field in your server config on WHMCS is set to cPanel and make sure your remote access key from your WHM is copied correctly into your access hash in WHMCS 0 Quote Link to comment Share on other sites More sharing options...
hostin4u Posted January 3, 2010 Author Share Posted January 3, 2010 Are you using cpanel/WHM ? if so make sure your Type field in your server config on WHMCS is set to cPanel and make sure your remote access key from your WHM is copied correctly into your access hash in WHMCS It is set to cPanel and remote access key is there. Any Ideas? Thanks. S. Warren Hostin4u 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Product Manager WHMCS John Posted January 5, 2010 WHMCS Product Manager Share Posted January 5, 2010 http://wiki.whmcs.com/Common_Troubleshooting_Tips#Server_Command_Error_-_Curl_Error_-_Couldn.27t_connect_to_host_.287.29 0 Quote Link to comment Share on other sites More sharing options...
