top container border
jvoegeli
Ok on the top container I made my logo a clickable link back to the homepage... well IE likes to put a bright blue border around the image when its a clickable link... i tried to create my own css class with another border the same color but it just puts that border on the outside of the blue... is there anyway to get rid of the bright blue border around a clickable link?
http://www.vsupports.com/billing/
you can see what I'm talking abt ^
<img src="http://vsupports.com/images/vsslogowhmcs.gif" alt="Voegeli Support Solutions" /></a>
Change to:
<img src="http://vsupports.com/images/vsslogowhmcs.gif" alt="Voegeli Support Solutions" border ="0"  /></a>
Or you could add to your CSS (better rnethod, but does this for all images):
#img{
border: none;
awesome! thanks for the quick reply... just a side note tho the css code did not work... :( added it saved and uploaded also cleared temp files but still the blue border remained... the first method worked tho just going to have to remember to change with all linked images.
Thanks again!
