Custom Server Module and Multiple Products
swhitley
I have developed a custom server provisioning module. The module is functioning perfectly when the order only contains one product. If the customer selects two or more products, the $params variable in the module only contains information for one product.
Shouldn't $params contain information for each product in the order? If not, shouldn't the module be called multiple times?
Thanks.
A little more information on this problem: The first item has an "Active" status, but the second item has a "Pending" status. I assume that is why the module isn't running for the second item. Is it possibly related to fraud prevention? If so, is there an option to allow all items to save with an "Active" status?
The module is called multiple times.
Check your productsfor the auto setup options
eg..
Automatically setup the product as soon as an order is placed
Automatically setup the product as soon as the first payment is received
Automatically setup the product when you manually accept a pending order
Do not automatically setup this product
Thanks.
Yes, I have this selected:
- Automatically setup the product as soon as an order is placed.
Is it possible that I'm missing a return value to make sure that the module is called after the first item? It looks like it just stops at the first item and places the second item in a pending status.
