Problem with Linkpoint Gateway
tjhartweg
Does anyone use First Data's Linkpoint Gateway? I've discovered that Port 1129 must be open bi-directionally, which HostGator won't do, since I'm on a reseller machine. A dedicated server isn't really an option right now.
The same goes for a client who just switched from USA ePay to First Data. The shopping cart and gateway are not communicating, and all of the settings have been verified with First Data.
Has anyone else run into this? I'm finding it hard to believe that all Linkpoint customers are on dedicated machines. Thanks for any insight!
