Need help installation
Nikkster
If the page is totally blank than maybe its a permissions issue, does the rest of WHMCS load (it should say error connecting to database as its not setup).
Also can you give us the links to your site? We won't actually be able to do any harm as we don't know the mysql passwords/users and we don't know your license key, so at best we could just view the installation page ;)
ok, we are getting somewhere....
even though php is working there are somethings not installed or missing.
WHMCS requires the following in order to run:
PHP Version 4.2.x or later
MySQL Version 4.1.x or later
Curl Support (with SSL support)
GD Image Library
Ioncube Loaders Support
Talk to your host to get them installed.
GD Image Library
I'm the host so I think I can install these things by myself but thanks for asking :)
