Problem to retrieve orderid
For a remote order form I need to retrieve the orderid from the database to get the order accepted by the available api code.
I use the script matt posted here on the forum http://forum.whmcs.com/showthread.php?t=12169&highlight=remote+order+form
My question: How can I retrieve the order ID in my form to get the accept order api working:
$postfields["action"] = "acceptorder";
$postfields["orderid"] = "ORDERID";
Thanks in advance.
Oops, here it is :)
The bold part is where I want to retrieve the orderd id.
<?php
$whmcsurl = "WHMCS URL";
$apiusername = "USERNAMEr"; # Admin username goes here
$apipassword = "PASSWORD"; # Admin password goes here
if ($_POST["action"]=="submit") {
# Get Values
$pid = trim(htmlentities($_POST["pid"]));
$firstname = trim(htmlentities($_POST["firstname"]));
$lastname = trim(htmlentities($_POST["lastname"]));
$companyname = trim(htmlentities($_POST["companyname"]));
$email = trim(htmlentities($_POST["email"]));
$address1 = trim(htmlentities($_POST["address1"]));
$address2 = trim(htmlentities($_POST["address2"]));
$city = trim(htmlentities($_POST["city"]));
$state = trim(htmlentities($_POST["state"]));
$postcode = trim(htmlentities($_POST["postcode"]));
$country = trim(htmlentities($_POST["country"]));
$phonenumber = trim(htmlentities($_POST["phonenumber"]));
$password = trim(htmlentities($_POST["password"]));
$password2 = trim(htmlentities($_POST["password2"]));
$tosagreement = $_POST["tosagreement"];
# Error Checking
if (!$firstname) {
$errors[] = "You did not enter your first name";
if (!$lastname) {
$errors[] = "You did not enter your last name";
if (!$email) {
$errors[] = "You did not enter your email address";
} elseif (!eregi("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@[a-z0-9-]+(\.[a-z0-9-]+)*(\.[a-z]{2,6})$", $email)) {
$errors[] = "The email address you entered is invalid";
if (!$address1) {
$errors[] = "You did not enter the first line of your address";
if (!$city) {
$errors[] = "You did not enter your city";
if (!$state) {
$errors[] = "You did not enter your state";
if (!$postcode) {
$errors[] = "You did not enter your postcode";
if (!$country) {
$errors[] = "You did not enter your country";
if (!$phonenumber) {
$errors[] = "You did not enter your phone number";
if (!$password) {
$errors[] = "You must enter a password";
} elseif ($password!=$password2) {
$errors[] = "The password you entered did not match";
if (!$tosagreement) {
$errors[] = "You must agree to the terms of service";
if (!$errors) {
# Submit Order
$apiurl = $whmcsurl."includes/api.php"; # URL to WHMCS API file
$postfields = array();
$postfields["username"] = $apiusername;
$postfields["password"] = md5($apipassword);
$postfields["action"] = "addclient";
$postfields["firstname"] = $firstname;
$postfields["lastname"] = $lastname;
$postfields["companyname"] = $companyname;
$postfields["email"] = $email;
$postfields["address1"] = $address1;
$postfields["address2"] = $address2;
$postfields["city"] = $city;
$postfields["state"] = $state;
$postfields["postcode"] = $postcode;
$postfields["country"] = $country;
$postfields["phonenumber"] = $phonenumber;
$postfields["password2"] = $password;
$query_string = "";
foreach ($postfields AS $k=>$v) {
$query_string .= "$k=".urlencode($v)."&";
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $apiurl);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_TIMEOUT, 100);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $query_string);
$data = curl_exec($ch);
curl_close($ch);
$data = explode(";",$data);
foreach ($data AS $temp) {
$temp = explode("=",$temp);
$results[$temp[0]] = $temp[1];
if ($results["result"]=="success") {
$clientid = $results["clientid"];
} else {
die("An error occured. Please contact support. ({$results['message']})");
$postfields["action"] = "addorder";
$postfields["clientid"] = $clientid;
$postfields["pid"] = $pid;
$postfields["paymentmethod"] = "mailin";
$postfields["noemail"] = "true";
$query_string = "";
$ch = curl_init();
curl_close($ch);
$orderid = $vars["OrderID"];
} else {
$postfields["orderid"] = $orderid;
$query_string = "";
$ch = curl_init();
curl_close($ch);
$invoiceid = $results["invoiceid"];
header("Location: ".$whmcsurl."cart.php?a=complete");
exit;
} else {
?><html>
<head>
<title>Order Form</title>
</head>
<body>
<h1>Order Form</h1>
<?php
if ($errors) {
echo "<p>The following errors occured.</p><ul>";
foreach ($errors AS $error) {
echo "<li>$error</li>";
echo "</ul>";
<form method="post" action="<?php echo $_SERVER["PHP_SELF"] ?>">
<input type="hidden" name="action" value="submit" />
<table>
<tr><td><b>Hosting Details</b></td></tr>
<tr><td>Hosting Package</td><td>
<input type="radio" name="pid" value="23"<?php if (($pid=="23")OR(!$pid)) { echo " checked"; } ?> /> Starter Package
</td></tr>
<tr><td><br /></td></tr>
<tr><td><b>Your Details</b></td></tr>
<tr><td>First Name</td><td><input type="text" name="firstname" size="30" value="<?php echo $firstname ?>" /></td></tr>
<tr><td>Last Name</td><td><input type="text" name="lastname" size="30" value="<?php echo $lastname ?>" /></td></tr>
<tr><td>Company Name</td><td><input type="text" name="companyname" value="<?php echo $companyname ?>" size="30" /></td></tr>
<tr><td>Email Address</td><td><input type="text" name="email" value="<?php echo $email ?>" size="30" /></td></tr>
<tr><td>Address 1</td><td><input type="text" name="address1" value="<?php echo $address1 ?>" size="30" /></td></tr>
<tr><td>Address 2</td><td><input type="text" name="address2" value="<?php echo $address2 ?>" size="30" /></td></tr>
<tr><td>City</td><td><input type="text" name="city" size="30" value="<?php echo $city ?>" /></td></tr>
<tr><td>State</td><td><input type="text" name="state" size="30" value="<?php echo $state ?>" /></td></tr>
<tr><td>Postcode</td><td><input type="text" name="postcode" size="30" value="<?php echo $postcode ?>" /></td></tr>
<tr><td>Country</td><td><input type="text" name="country" size="30" value="<?php echo $country ?>" /></td></tr>
<tr><td>Phone Number</td><td><input type="text" name="phonenumber" size="30" value="<?php echo $phonenumber ?>" /></td></tr>
<tr><td>Password</td><td><input type="password" name="password" size="30" /></td></tr>
<tr><td>Confirm Password</td><td><input type="password" name="password2" size="30" /></td></tr>
</table>
<p align="center"><input type="checkbox" name="tosagreement" /> I have read and agree to the <a href="http://www.yourdomain.com/terms.html" target="_blank">Terms of Service</a></p>
<p align="center"><input type="submit" value="Submit Order" /></p>
</form>
</body>
</html>
