Inmeso Posted June 15, 2009 Share Posted June 15, 2009 I have the following problem in WHMCS: I have some users (not all) where i cannot change their data. Like dedicated IP or username. If i change it and click save, it reloads the page with the old data. Even accepting orders do not work, and stay pending till i change it in the database using phpmyadmin. Does anyone else have this problem or even better : a solution? Thanks in advance. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted June 15, 2009 Share Posted June 15, 2009 The only time I saw that was when I'd done a update and missed a file or two (FTP simply failed to transfer). Have you opened a ticket with WHMCS? 0 Quote Link to comment Share on other sites More sharing options...
openmind Posted June 15, 2009 Share Posted June 15, 2009 I've seen it happen when MySQL is set to run in strict mode. Changing it to traditional solved the issue... 0 Quote Link to comment Share on other sites More sharing options...
inter Posted June 24, 2009 Share Posted June 24, 2009 I have just not saved changes to the package of users 0 Quote Link to comment Share on other sites More sharing options...
