elitbir Posted April 6, 2009 Share Posted April 6, 2009 Hi, My program at this address was previously published a new version is published QWHMCS. Please update your IE to be healthy to clear the cache item. Automatically updated on each landing QWHMCS control is your own. If the update still does not run on the Start menu QUpdate. Updated from the top menu then edit your settings to always. For this version should always be installed WHMCS 3.8.x version. http://dev.whmcs.com/index.php?version=20 at 569th In this version, as seen for Ticket API should have. To download : http://www.qtechnics.net/qwhmcs/ To source : http://code.google.com/p/qwhmcs/ 0 Quote Link to comment Share on other sites More sharing options...
dhs Posted April 6, 2009 Share Posted April 6, 2009 Thank You ElitBir.Net Internet Solutions 0 Quote Link to comment Share on other sites More sharing options...
FazeWire Web Services Posted April 6, 2009 Share Posted April 6, 2009 The mySQL mirror is down... Anyone have the installer file handy for the connector? Thanks! 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 6, 2009 Author Share Posted April 6, 2009 The mySQL mirror is down... Anyone have the installer file handy for the connector? Thanks! Thanks your feedback. I changed the address in mysql. You can check it again. http://www.qtechnics.net/qwhmcs 0 Quote Link to comment Share on other sites More sharing options...
FazeWire Web Services Posted April 6, 2009 Share Posted April 6, 2009 Thanks! Installing now... 0 Quote Link to comment Share on other sites More sharing options...
flip Posted April 7, 2009 Share Posted April 7, 2009 Just a few... suggestions: Current: Change to: Open Ticket -> Open Tickets Closed Ticket -> Closed Tickets Answered -> Answered Tickets Customer-Reply -> Customer Replied Database Connection Problem ! -> Database Connection Problem! Subname -> Surname What's an "about box"? Also you might want to change the minimum transparency.. As if you let go of the slider, when it is at 0, you can't see or find the window! (Perhaps 30-40% as minimum.) LOL After downloading from your website, installing, and configuring, it then asked to do an update. Why is the most recent version not available online for download? I found it won't connect to my database, as i think the server name (usually localhost, is now domain_name.com, but will not connect. I think most servers connect at 3306 or close too...? After the upgrade, BalloonNewAnswer now = Database Connection Problem ! When ErrorDatabase = Database Connection Problem ! Strange... FYI A great job so far! Well done! 0 Quote Link to comment Share on other sites More sharing options...
LemonBarley Posted April 7, 2009 Share Posted April 7, 2009 what to fill in in "other setting" API Username API Password API Address ? 0 Quote Link to comment Share on other sites More sharing options...
flip Posted April 7, 2009 Share Posted April 7, 2009 Why would it need the API if it has MySQL access? Lemon Barely: 1. To create a user with access to API. - Click on Administrator Groups - Create a new group called "API_Only" for example - Set permissions to ONLY have access to API (very last check box) - Save 2. Create a new user in the API_Only group. - Create user - Give user name + password - Set user to API_Only group - Save Now enter in the API user and password in the program or script, and Bingo! You now have given a third party access to your script, but ONLY to the API area, and not your raw data. (: 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 7, 2009 Author Share Posted April 7, 2009 Just a few... suggestions: Current: Change to: Open Ticket -> Open Tickets Closed Ticket -> Closed Tickets Answered -> Answered Tickets Customer-Reply -> Customer Replied Database Connection Problem ! -> Database Connection Problem! Subname -> Surname First, Thanks for the notice of the language problem. Sufficient level of English is not my case ... I'm using Google translate your correspondence. What's an "about box"? About the program window opens on each landing and AboutBox opening is not set. Also you might want to change the minimum transparency.. As if you let go of the slider, when it is at 0, you can't see or find the window! (Perhaps 30-40% as minimum.) LOL Yes you are right. 20% of the six seem unreasonable. At least 20% in the new version to be allowed to correct. After downloading from your website, installing, and configuring, it then asked to do an update. Why is the most recent version not available online for download? 1.2.0.0 is the version published on the site. 1.2.0.0 update is only relevant configuration files are on the. I found it won't connect to my database, as i think the server name (usually localhost, is now domain_name.com, but will not connect. I think most servers connect at 3306 or close too...? Mysql already open to anyone in a position in Plesk. Easy remote access to CPanel and DirectAdmin can be adjusted. No can do something about this case. Good programmers develop the complete WHMCS API can be employed via the API. After the upgrade, BalloonNewAnswer now = Database Connection Problem ! When ErrorDatabase = Database Connection Problem ! Yes. You read right. Had a string of small errors. You can write your own language you want. Related field is the text of notification of new replies. Strange... FYI A great job so far! Well done! Thanks for your feedback. feedback the program will become more advanced. 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 7, 2009 Author Share Posted April 7, 2009 what to fill in in "other setting" API Username API Password API Address ? Authorized user information in WHMCS API. 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 7, 2009 Author Share Posted April 7, 2009 Why would it need the API if it has MySQL access? Remote access to mysql to take tickets. WHMCS is not open source, a new process, the process of answering exactly do not know. In such a case prepared by WHMCS would use the API. And answer process with WHMCS also sending email is required. Lemon Barely: 1. To create a user with access to API. - Click on Administrator Groups - Create a new group called "API_Only" for example - Set permissions to ONLY have access to API (very last check box) - Save 2. Create a new user in the API_Only group. - Create user - Give user name + password - Set user to API_Only group - Save Now enter in the API user and password in the program or script, and Bingo! You now have given a third party access to your script, but ONLY to the API area, and not your raw data. (: Thank you for your comments. 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 7, 2009 Author Share Posted April 7, 2009 Hi, I thought and decided. Mysql remote connection permission seems a very risky way. PHP-XML-based API for the security of the server started to write. This and more secure, and will add more speed. To see the next version. I open to suggestions. 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted April 7, 2009 Author Share Posted April 7, 2009 Hi again, QWHMCS has been updated. Remote mysql connection with version 1.4.123.76 do not need anymore. Restart the current version. QUpdate will notice. If it does not give you to start from the Start Menu. After the update is completed, a file on the desktop will qapi.txt name. Change the name of qapi.php as qapi.txt file and upload your WHMCS to the includes folder. If you want to change the date format, $dateformat variable changes in qapi.php can. Now mysql connection is not required for QWHMCS. If you wish to remove before installing the MySQL Connector. About the problems you can contact us or support our site. Thank you for using this software. 0 Quote Link to comment Share on other sites More sharing options...
wsa Posted April 7, 2009 Share Posted April 7, 2009 I check today 0 Quote Link to comment Share on other sites More sharing options...
PauGasol Posted May 9, 2009 Share Posted May 9, 2009 Works with v4 ? Thanks 0 Quote Link to comment Share on other sites More sharing options...
abdofikry Posted June 28, 2009 Share Posted June 28, 2009 the new version is Great and easy to use , it work with version 4 very Fine if U R Open to Suggestions : 1 - hope to make it lighter taking less resources . 2 - support arabic language cause we can`t see ticket content so i should open in it in WHMCS to see and reply . 3 - if possible , adding alert for new orders and cancellations will be nice . 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted July 1, 2009 Author Share Posted July 1, 2009 Hi, Arabic language support will have to work for. Orders and open orders to be displayed is thought to be warned. Thank you for your Contribution. the new version is Great and easy to use , it work with version 4 very Fine if U R Open to Suggestions : 1 - hope to make it lighter taking less resources . 2 - support arabic language cause we can`t see ticket content so i should open in it in WHMCS to see and reply . 3 - if possible , adding alert for new orders and cancellations will be nice . 0 Quote Link to comment Share on other sites More sharing options...
martynh Posted July 22, 2009 Share Posted July 22, 2009 I tried to download this today but when i download it, it shows as 0kb and does not work anywhere else this can be downloaded from, would really like to try 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted July 22, 2009 Author Share Posted July 22, 2009 I tried to download this today but when i download it, it shows as 0kb and does not work anywhere else this can be downloaded from, would really like to try please check link ? http://www.elitbir.net/destek/downloads.php?action=displaycat&catid=4 0 Quote Link to comment Share on other sites More sharing options...
elitbir Posted July 22, 2009 Author Share Posted July 22, 2009 sorry system error. i'm resolved problem. try again. 0 Quote Link to comment Share on other sites More sharing options...
martynh Posted July 23, 2009 Share Posted July 23, 2009 Perfect, thank you 0 Quote Link to comment Share on other sites More sharing options...
