Austdata Posted November 29, 2008 Share Posted November 29, 2008 I'm very tired and need some basic advice in really plain English. My web designer has come up with this Basic Sub Page and I need to know what needs to be changed so it can be used to integrate with the WHMCS cart, etc. Cheers, Mike (Who's still up at 5:00AM). :shock: 0 Quote Link to comment Share on other sites More sharing options...
randy Posted November 29, 2008 Share Posted November 29, 2008 What we did was have the header and footer in thier own files then just included the files in the TPL theme files. I think there is a lot of help on the forums if you search for integration. 0 Quote Link to comment Share on other sites More sharing options...
Austdata Posted November 29, 2008 Author Share Posted November 29, 2008 Thanks Randy, That shouldn't be a problem with the footer. I'm not sure about the header though. My problem, apart from lack of sleep, is I need to pass the information on to the designer who doesn't know what WHMCS is and he lives way over in Perth, WA. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted November 30, 2008 Share Posted November 30, 2008 For the record and so there's no further confusion, there is no advertising allowed on the WHMCS forums, anywhere. If you offer to pay, or if you offer to do something *for* pay, that's advertising, and it will be removed. 0 Quote Link to comment Share on other sites More sharing options...
Austdata Posted November 30, 2008 Author Share Posted November 30, 2008 I knew it was something like that, so many forums, so many rules. 0 Quote Link to comment Share on other sites More sharing options...
randy Posted November 30, 2008 Share Posted November 30, 2008 For the record and so there's no further confusion, there is no advertising allowed on the WHMCS forums, anywhere. If you offer to pay, or if you offer to do something *for* pay, that's advertising, and it will be removed. Did I do something like that or you talking to the thread starter? I did not see anything like that so I am confused... Thanks Randy,That shouldn't be a problem with the footer. I'm not sure about the header though. My problem, apart from lack of sleep, is I need to pass the information on to the designer who doesn't know what WHMCS is and he lives way over in Perth, WA. Our designer did not know anything about it either, except when I had him design our site I told him I needed a stand alone header, stand alone footer and I would supply the middle content. We then also made a header_secure.php with all the https:// links to images so there would be no security certificate error. It worked out nicely. I would say if yours is not cut up the same, just take the top part of your code and make your own header to include in the tpl files. 0 Quote Link to comment Share on other sites More sharing options...
bear Posted November 30, 2008 Share Posted November 30, 2008 @randy: No, there are some posts that were removed for it, and apparently some confusion over why with the members involved. Nothing wrong with your contributions, and I'm sorry for any confusion. 0 Quote Link to comment Share on other sites More sharing options...
Austdata Posted November 30, 2008 Author Share Posted November 30, 2008 @BEAR: Was it one of mine? 0 Quote Link to comment Share on other sites More sharing options...
bear Posted November 30, 2008 Share Posted November 30, 2008 @Austdata: Indirectly. Detailed answer via PM. 0 Quote Link to comment Share on other sites More sharing options...
Austdata Posted November 30, 2008 Author Share Posted November 30, 2008 Okay, all good now I understand. I sailed just a little to close to the wind for that post to stay afloat. (Hmm, wonder why I've gone all nautical tonight?) 0 Quote Link to comment Share on other sites More sharing options...
