beatrix Posted October 25, 2008 Share Posted October 25, 2008 how i can track promotion code that already usage by my customer, on report menu only show me number of promotion code used, but i can't list which order alredy used my promotion code ... better if in list order or list product we can filter by promotion code. so we can track our promotion is success or not .... or i mist something, anyone can help me ? 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted October 25, 2008 Share Posted October 25, 2008 If a promotion code was used it is displayed on the order. 0 Quote Link to comment Share on other sites More sharing options...
R-n-R Posted October 25, 2008 Share Posted October 25, 2008 I think I understand what beatrix is asking. (I am new to WHMCS so I dont know the answer) I believe he is asking for stats on each code, a quick and easy way to track the stats on what codes are working and the ones that are not. I would think it would be to time consuming to look at each and every order to see what code was used, more of a percentage and/or numbers of which promotions code where used and maybe by each customer on a stats page like web stats are displayed. 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted October 25, 2008 Share Posted October 25, 2008 Well as you have to manually activate each order anyway you'll definitely see who's using the promo codes, you can also see how often a promo code has been used in Configuration > Promotions. However a page or report with all the orders that have used a promo code would be handy. 0 Quote Link to comment Share on other sites More sharing options...
R-n-R Posted October 25, 2008 Share Posted October 25, 2008 Well as you have to manually activate each order anyway you'll definitely see who's using the promo codes, This is true, if your the only person that will be doing this, but in a operation of more than one person, it could be a issue. 0 Quote Link to comment Share on other sites More sharing options...
othellotech Posted October 26, 2008 Share Posted October 26, 2008 select * from tblorders where promocode="20PCoff" its easy enough to do a report of promo usage ... 0 Quote Link to comment Share on other sites More sharing options...
beatrix Posted October 27, 2008 Author Share Posted October 27, 2008 select * from tblorders where promocode="20PCoff" its easy enough to do a report of promo usage ... yes right, now i always do it manual query. just make sure that this menus not avaliable in admin menu. its will be nice feature if WHMCS have this feature Promotion Detail Report Menu. Or we can filter this from List All Order Menu. 0 Quote Link to comment Share on other sites More sharing options...
Rafat Bandak Posted June 14, 2022 Share Posted June 14, 2022 You can do it using the Reports Menu then Reports then Promotions Usage select the date range and for each Promotion Code select Drill Down, it is handy and give you the required information. 0 Quote Link to comment Share on other sites More sharing options...
