add order ssl problem
simplybe
Bit of an odd problem that started today. When i go to a clients details in whmcs and select add order i get an ssl warning claiming the page contains insecure items. The odd thing is that i did 3 orders without any ssl errors and then on the 4th the warnings started to appear.
No changes have been made to the whmcs files etc the error just started. I have clicked the yes button to show insecure items and saved the source code, I then did the same page and clicked no and saved the code. I then used beyond compare to see what was causing the error but both pages are identical ?
The only thing i can think of is that the add order seems to be calling admin/clientarea.php when loading. Does whmcs make a call to WHMCS' server and that could be the cause of the ssl issue ?
Ssl on the site and through the order pages is fine. the only place it appears is when manually adding an order. I am on V.3.6.2
Ok I now realise that there is no such file as /admin/clientarea.php but whmcs is looking for it and the 404 is causing the ssl error.
The problem code seems to be generated by ordersadd.php (encrypted file)
<iframe src="clientarea.php" id="orderfrm" name="orderfrm"
this is trying to load /admin/clientarea.php
strange but not a big deal
