kopw123 Posted August 3, 2008 Share Posted August 3, 2008 I am trying to configure whmcs. I can't seem to create accounts. I keep getting the message " Unable to validate setting for cpmod: X3 ". What can I do, can anyone help? Link to comment Share on other sites More sharing options...
Retired Forum Member WHMCS Joe Posted August 4, 2008 Retired Forum Member Share Posted August 4, 2008 Hi The variables are case sensitive the correct theme would be x3 Not X3 must be the same as it is in your WHM/Cpanel. You will need to update it in the modules settings tab for that package. Joe Link to comment Share on other sites More sharing options...
churchmedic Posted September 8, 2008 Share Posted September 8, 2008 did not work here. Strange as this used to work - suddenly stopped after upgrade of whmcs the account package for us is called Silver and we have it in the whmcs system as Silver any ideas ? Link to comment Share on other sites More sharing options...
Frankc Posted March 5, 2018 Share Posted March 5, 2018 The same problem and the case sensitive might be because of internal WHMCS bug (display at least the package with capital letter first, while on database it appear correct as lowercase) Unable to validate setting for cpmod: paper_latern The paper_latern is also not a package, but a cpanel theme that cannot be chanced and part of the package saweb_jbdagents Link to comment Share on other sites More sharing options...
brian! Posted March 5, 2018 Share Posted March 5, 2018 it should be paper_lantern Link to comment Share on other sites More sharing options...
Frankc Posted March 5, 2018 Share Posted March 5, 2018 (edited) I will check but it is then WHMCS problem somewhere. Always worked untill the last upgrades month or two ago and nothing changed (or can be changed) server side. (the error above is from WHMCS self, the cpanel theme is correct paper_lantern Did database search and update and found several so thank you a lot, should work now thanks Edited March 5, 2018 by Frankc Link to comment Share on other sites More sharing options...
