[FIXED] PDF - Problem
did you check the code in your phpconfig.php
foreach ($invoiceitems AS $item) {
       if (strlen($item["description"])>90) {
               $pdf->Cell(148,6,substr($item["description"],0,90),1);
               $pdf->Cell(40,6,$currencysymbol." ".$item["amount"]." ",1,0,'R');
               $pdf->Ln();
               $pdf->Cell(148,6,substr($item["description"],90),1);
               $pdf->Cell(40,6,"",1,0,'C');
       } else {
               $pdf->Cell(148,6,$item["description"],1);
       $pdf->Ln();
i encountered this issue also, all the invoice content is going over the tables/margins
i have a custom pdfconfig.php and it started to look awkward right after the upgrade
from what i noticed: the invoices after the upgrade are having the footer working: "page 1/1"
