lekinha Posted May 10, 2008 Share Posted May 10, 2008 as I try to import accounts of WHM, I can not. The WHM Import SCRIPT not list my accounts. And have no message of error. Revise the packages, and are correct. I hope you could help me. Tranks 0 Quote Link to comment Share on other sites More sharing options...
weverette Posted July 7, 2008 Share Posted July 7, 2008 WHMCS seems to be functioning properly everywhere else. I've setup the server with the coorect key, user and pass, ip. Everything is correct. I get nothing on the import screen but the default table headers. No error, nothing. 0 Quote Link to comment Share on other sites More sharing options...
Terry Posted July 9, 2008 Share Posted July 9, 2008 I had the same thing, e-mail support and they will send you the modified file. 0 Quote Link to comment Share on other sites More sharing options...
txkhomes Posted July 9, 2008 Share Posted July 9, 2008 Make sure that your packages are setup correctly under module setting Cpanel would be username_package name 0 Quote Link to comment Share on other sites More sharing options...
