iDevAffiliate problem
I'm trying to intergrate iDevAffiliate 5 with WHMCS version 3.5.1.
Firstly, the file includes/checkoutscript.php didn't exist, I have created it and placed the following code in it:
<?php
$idev_query = mysql_query("select amount from tblorders WHERE id='$orderid'");
$idev_query = mysql_fetch_array($idev_query);
$idev_saleamt = $idev_query['amount'];
$site_url = "http://www.domain.com/partner//sale.php?idev_saleamt=$idev_saleamt&idev_ordernum=$orderid";
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $site_url);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_TIMEOUT, 100);
$result = curl_exec($ch);
curl_close($ch);
But this doesnt work. The order goes through correctly in WHMCS, but the sale isn't logged in iDv, despite iDev's control panel showing me the IP is logged and the session is valid.
Now, it did work using iDev's own code suggestion, which is:
<?php
$idev_saleamt = $idev_query[amount];
print "<img border=\"0\" src=\"http://www.domainname.com/partner//sale.php?idev_saleamt=$idev_saleamt&idev_ordernum=$orderid\" width=\"1\" height=\"1\">";
However, when ordering your browser will throw up an error about serving non secure pages, the page then goes blank with a very tiny 1 pixel in dimension image box on the page.
The order goes through OK in WHMCS and the sale is logged in iDev, but both the error and the blank page are not desirable.
Does anyone have any recommendation's?
You're going to get a 1 pixel by 1 pixel display because you are specifying it on your print line:
You are going to get the unsecure error as you have a nonsecure hard link specified.
If it's on the same hosting account, just remove the http://www.domainname.com part so it just starts with /partner/sale.php.... Otherwise use https://
Its not on the same account.
I added https last night and setup a test certificate on the site. But I still receive a blank page. The sale is registered, but the invoice is not displayed, it's just a blank page.
I read here:
http://forum.whmcs.com/showthread.php?t=4205&highlight=idevaffiliate
That the method iDev suggests actually breaks the order process, this is what I'm seeing. But the method suggested on that thread doesn't work for me either.
Cracked it - Not sure of the exact problem. Ended up installing idev in another location and using the following code:
{if $ispaid}
<img border="0" src="../../../../partner/sale.php?profile=72198&idev_saleamt={$amount}&idev_ordernum={$invoiceid}" width="1" height="1" />
{/if}
That needs to go into whmcsinstalldir/templates/orderforms/cart/complete.tpl
This time its installed on the same account as WHMCS itself.
  • 8 months later...
{if $ispaid}
{/if}
Hello :) Thank you for this.
Can you tell me what the
profile=72198 is?
I see where to place this code and do you think i can use a full URL or should you only use relative paths?
  • 3 months later...
Sorry to dig up an old thread but I am having issues since upgrading to v4
<?php
$ch = curl_init();
curl_close($ch);
The above worked on v3.x but not on v4
Anyone have any ideas?
Thanks!
  • 4 weeks later...
<?php
$ch = curl_init();
curl_close($ch);
Thanks!
I've only just moved over to v4, but will be testing this tomorrow.
How did that work out?
Hi, worked fine, tested it earlier today, using idev 6.0.1 and WHMCS 4.0.2.
Here's what I'm using:
{php}
$orderid = $this->get_template_vars('orderid');
$result = select_query("tblorders","amount",array("id"=>$orderid));
$data = mysql_fetch_array($result);
$amount = $data["amount"];
$this->assign('amount',$amount);
{/php}
<img src="../../../../partner/sale.php?profile=33&idev_saleamt={$amount}&idev_ordernum={$orderid}&ip_address={$smarty.server.REMOTE_ADDR}" width="1" height="1" border="0" />
partner being the installation of idev, on the same domain as WHMCS.
It goes in templates/orderforms/cart/complete.tpl between:
{if $ispaid}
{/if}
How does one disable the default whmcs affiliate system? I have it unchecked yet it still pops up on the index and other places.
{php}
{/php}
{if $ispaid}
{/if}
  • 4 weeks later...
{php}
{/php}
{if $ispaid}
{/if}
Just curious - I use the same code and the order number for the commission is N/A, does it show for you?
