Products listed side by side on cart.php
KuJoe
I already did a search with no luck so if this was asked and answered previously I apologize. I am trying to get all of my products listed on the cart.php page side by side instead of stacking on top of each other. I've looked in the products.tpl but I must be missing something as I can't see what to remove/edit. :(
Wow, I didn't expect to ever get an answer after scouring for 3+ days and various programmers for hire declining my offers. I have since found an alternative, only offering 1 package. :D Thanks for the reply though, maybe Chris is still interested. ;)
Here is what Baji sent me.....
I hope I have all the .css.
What's your site?
<table style="width: 100%; border: 1px solid #e0e0e0;" cellpadding="2" cellspacing="20" >
<tr>
{foreach key=num item=product from=$products}
<td valign="top"><div class="cartboxproducts">
<p class="productname"><strong>{$product.name}</strong> {if $product.qty!=""}<em>({$product.qty} {$LANG.orderavailable})</em>{/if}</p>
<div class="surround">
{if $product.description}{$product.description}<br />{/if}
<div style="margin:5px;padding:2px;color:#cc0000;">
{if $product.paytype eq "free"}
{$LANG.orderfree}
{elseif $product.paytype eq "onetime"}
{$product.pricing.onetime} {$LANG.orderpaymenttermonetime}
{elseif $product.paytype eq "recurring"}
{if $product.pricing.monthly}{$product.pricing.monthly}<br />{/if}
{if $product.pricing.quarterly}{$product.pricing.quarterly}<br />{/if}
{if $product.pricing.semiannually}{$product.pricing.semiannually}<br />{/if}
{if $product.pricing.annually}{$product.pricing.annually}<br />{/if}
{if $product.pricing.biennially}{$product.pricing.biennially}<br />{/if}
{/if}
</div>
</div><br>
<div align="center"><input type="button" value="{$LANG.ordernowbutton}"{if $product.qty eq "0"} disabled{/if} onclick="window.location='{$smarty.server.PHP_SELF}?a=add&pid={$product.pid}'" /></div>
</div>
</td>
{if $num is not div by 2}
</tr>
<tr>
{/if}<br />
{/foreach}
</tr>
</table>
<p align="center"><input type="button" value="{$LANG.viewcart}" onclick="window.location='cart.php?a=view'" /></p>
.cartboxproducts {
 width: 100%;
 height:250px;
 margin-left: auto;
 margin-right: auto;
 padding: 10px;
 background-color: #f7f7f7;
 border: 1px dotted #cccccc;
.productname {
 font-size:14px;
.surround {
 border: 1px solid #D8D8DA;
 padding: 5px;
Let me know if this works!
Though I havent got round to testing it yet, and tbh I actuall like the layout I got by mixing up 2 sugestions I got in another thread......
I now have this :D
https://www.xtrgameservers.com/services/cart.php?gid=0000000006
Heres the thread, including how I ended up with my end result ;)
http://forum.whmcs.com/showthread.php?t=11196
  • 2 months later...
I am trying to achieve the same sort of thing, I would like the Products side by side in one table. With order buttons underneath the product.
I have played around and cant seem to get it to work like that.
I have copied and pasted the example code to both the files, when i look at my site, nothing has changed, the products are listed below each other?
Can someone help me place 4 products into one table, if a fifth is added a new table below is made?
Product1 Product2 Product3 Product4
  • 4 months later...
Just thought I'd update this thread. I know its been a while since Baji26 pointed me in the direction, and since then I have done some major tweaking.
One thing is that the column system, is now set in div format. Making it even simpler to style.
To increase the number or columns change the below value to whatever you need.
{assign var=cols value=3}
Here's the code for the tpl file: - Works fully in 3.8.1
<link rel="stylesheet" type="text/css" href="templates/orderforms/cart/style.css" />
<p align="center" class="cartheading">{$LANG.cartbrowse}</p>
<div class="cartbox" align="center"><strong>
{foreach key=num item=productgroup from=$productgroups}
{if $gid eq $productgroup.gid}
{$productgroup.name} |
{else}
<a href="{$smarty.server.PHP_SELF}?gid={$productgroup.gid}">{$productgroup.name}</a> |
{/if}
{/foreach}
{if $loggedin}<a href="{$smarty.server.PHP_SELF}?gid=addons">{$LANG.cartproductaddons}</a> | {/if}
{if $registerdomainenabled}<a href="{$smarty.server.PHP_SELF}?a=add&domain=register">{$LANG.registerdomain}</a> |{/if}
{if $transferdomainenabled}<a href="{$smarty.server.PHP_SELF}?a=add&domain=transfer">{$LANG.transferdomain}</a> |{/if}
<a href="{$smarty.server.PHP_SELF}?a=view">{$LANG.viewcart}</a>
</strong></div>
<br />
<div id="columnbox_main">
<div class="columnbox_list">
<div class="columnbox_row">
{foreach name=list key=num item=product from=$products}
<div class="columnbox_product">
<div class="columnbox_productholder">
<div class="columnbox_productinfo">
<center style="min-height: 30px;"><h3>{$product.name}</h3></center> {if $product.qty!=""}<em>({$product.qty} {$LANG.orderavailable})</em>{/if}
</div>
<div class="columnbox_productprice">
<div style="margin:5px;padding:2px;color:#6ba806;">
{$LANG.orderfree}
{/if}
</div>
<div align="center" style="margin-bottom: 10px;"><input type="button" value="{$LANG.ordernowbutton}"{if $product.qty eq "0"} disabled{/if} onclick="window.location='{$smarty.server.PHP_SELF}?a=add&pid={$product.pid}'"/></div>
</div>
</div>
</div>
{if not (($smarty.foreach.list.index +1) mod $cols)}
{if not $smarty.foreach.list.last}
</div><div class ="columnbox_row">
{/if}
{/if}
{if $smarty.foreach.list.last}
{* pad the cells not yet created *}
{math equation = "n - a % n" n=$cols a=$products|@count assign="cells"}
{if $cells ne $cols}
{section name=pad loop=$cells}
<div> </div>
{/section}
{/if}
</div>
{/if}
{/foreach}
</div>
</div>
<p align="right"><input type="button" value="{$LANG.viewcart}" onclick="window.location='cart.php?a=view'" /></p>
Here is the values to use in the .css file, though could be changed to whatever you want, obviously depending on your layout.
#columnbox_main { color:000}
.columnbox_row { margin-bottom:15px; overflow:auto;}
.columnbox_product {width:200px; float:left; margin: 0px 5px 0px 5px; }
.columnbox_productholder { background: #fff; padding: 5px; border: 1px dashed #000; text-align:center; }
.columnbox_productprice { overflow:auto;}
Big credits go to to BAJI26 for setting me on the path in the first place:D
It's actually code that Balji26's gave me in April last year...Though he could have got it from you, not sure...
If he did, then obviously credit goes to you too :)
Incidentally, what do you think of the div layout tweak/mod....... I personally find it gives far more freedom when laying the products out.
Also, I'm currently working on making it so different product groups display differently, i.e our game servers in 3 column, merchandise 1 column, etc etc
Will post the code when I'm done.
I am referring to this part
and
{/if}
{/if}
<div> </div>
{/section}
{/if}
I can't see that in the original given to you by BAJI26. Please point it out. Edited by sparky
