webace Posted September 2, 2006 Share Posted September 2, 2006 Hi Everyone I hope somone can offer some advice with 2 issues I am having 1) Email piping is not work for me, I have double checked the format and all is correct according the manual, can anyone recommend a alternate for I can try for the pipe command 2) Being in South Africa the co.za TLD is my main seller however the whmcs script is not checking this corectly - I have tried a few changes in the domaincheckerconfig.php file but still no luck Thanks in advance 0 Quote Link to comment Share on other sites More sharing options...
xxxacp Posted September 2, 2006 Share Posted September 2, 2006 Did you submit a trouble ticket? This is the quickest way to get support for your issues. 0 Quote Link to comment Share on other sites More sharing options...
webace Posted September 3, 2006 Author Share Posted September 3, 2006 Hi Yes I did - whmcs has the best support I have ever seen with these billing systems and matt helped resolve the mystery around my email piping. Thank you 0 Quote Link to comment Share on other sites More sharing options...
