pRieStaKos Posted October 7, 2024 Share Posted October 7, 2024 (edited) After an issue with the cron job and when cron successfully ran, admin area returns the following issue: Quote TypeError: Unsupported operand types: int + string in /var/www/domain.com/public_html/modules/widgets/Automation.php:70 Stack trace: #0 /var/www/domain.com/public_html/vendor/whmcs/whmcs-foundation/lib/Module/AbstractWidget.php(0): WHMCS\Module\Widget\Automation->generateOutput() #1 /var/www/domain.com/whmcs_files/templates_c/799ef8776f589d036aafa664c5d0f2dc23473da8_0.file.homepage.tpl.php(148): WHMCS\Module\AbstractWidget->render() #2 /var/www/domain.com/public_html/vendor/smarty/smarty/libs/sysplugins/smarty_template_resource_base.php(123): content_6702d0c7932f13_73453097() #3 /var/www/domain.com/public_html/vendor/smarty/smarty/libs/sysplugins/smarty_template_compiled.php(114): Smarty_Template_Resource_Base->getRenderedTemplateCode() #4 /var/www/domain.com/public_html/vendor/smarty/smarty/libs/sysplugins/smarty_internal_template.php(216): Smarty_Template_Compiled->render() #5 /var/www/domain.com/public_html/vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(232): Smarty_Internal_Template->render() #6 /var/www/domain.com/public_html/vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(116): Smarty_Internal_TemplateBase->_execute() Anyone got the same issue and have an idea on how to resolve this ? Thank you in advance. Edited October 7, 2024 by pRieStaKos 0 Quote Link to comment Share on other sites More sharing options...
Solution pRieStaKos Posted October 7, 2024 Author Solution Share Posted October 7, 2024 (edited) UPDATE: Just found that `tbllog_register` table got "InvoiceReminders" `string` (serialized) values instead of `int` and `created_at` the latest WHMCS upgrade date... Edited October 7, 2024 by pRieStaKos 0 Quote Link to comment Share on other sites More sharing options...
