Issue after configuring for cloudflare
WALU2024
Go to solution Solved by ROQ,
Hey all,
So today we activated cloudflare and made all the necessary changes.
However, since doing so, when attempting to make any changes via WHMCS admin, on hitting "Save" it appears to log us out (we are sent to the WHMCS admin login screen.
(We were also getting a CSRF Protection Token error, so tried disabling that for a while, but the logout issue is still occuring)
Any advice, suggestions, tips appreciated.
It wouldn't be right to compromise security to solve the problem.
Try going to General settings - Security
https://prnt.sc/0u9hXErir-LS
Adjust as shown in the image.
Cloudflare ipv4 addresses:
https://www.cloudflare.com/ips/
5 hours ago, WALU2024 said:
Hey all,
14 hours ago, YamanHosting said:
I appreciate that. Thank you for sharing.
I just noticed an alert in the system health that suggested that Cloudflare hadn't been set up within WHMCS, and to click to "automatically" set up, which seems to have added those IPs as you suggested.
