Language problem
totomcs
i have upgrade whmcs to 3.6 beta version. There is a problem now with our language select.
With version 3.5.1 we could use setlanguage=true if we change the language then changes the langauge also.
But with new version ( 3.6 ) it do not change ( exluding setlanguage=true ) it takes the default language (english).
This problem appears not with domainchecker.php . It appears only with our own created pages we do not understand why it don't work with version 3.6. Version 3.5.1 was proceding perfectly.
LIKE THIS ONE:
<?php
require("dbconnect.php");
require("includes/functions.php");
$pagetitle = $_LANG['clientareatitle'];
$pageicon = "images/support/clientarea.gif";
$breadcrumbnav=''.$_LANG['globalsystemname'].'';
require("init.php");
if ($_SESSION['loggedinstatus']=="true") {
# User is Logged In - put any code you like here
# Define the template filename to be used without the .tpl extension
$templatefile = "new_page";
To assign variables in Smarty use the following syntax.
$smarty->assign('variablename', $value);
This can then be used as {$variablename} in the template
include("display.php");
Kind regards,
