mddrch Posted January 23, 2024 Share Posted January 23, 2024 Our domain registrar is InternetX. I recently bought the "Existing Domains" extension on the marketplace, allowing customers to use existing domains when buying hosting services with us. This works well with domains that were previously bought via our WHMCS, and consequently registered with InternetX. My question now it this: What about domains that the customer already owns with InternetX? Do they need to be transferred to our WHMCS system? Or "use existing domain and update nameservers?" I guess I am a bit confused, because in both cases the domain would be with InternetX. Is there a way to synchronize customer domains between WHMCS and a registrar? Would this even be within the scope of the module? Thanks for any clarification 0 Quote Link to comment Share on other sites More sharing options...
Solution RadWebHosting Posted January 27, 2024 Solution Share Posted January 27, 2024 On 1/23/2024 at 3:36 AM, mddrch said: My question now it this: What about domains that the customer already owns with InternetX? Do they need to be transferred to our WHMCS system? Yes, they should be transferred into your account at the registrar. Different TLDs have different procedures for this, often known as Inter-registrar transfers, domain push, or domain trade. On 1/23/2024 at 3:36 AM, mddrch said: Or "use existing domain and update nameservers?" This would be the appropriate selection for when your clients are using any domain that is not managed within your WHMCS. On 1/23/2024 at 3:36 AM, mddrch said: Is there a way to synchronize customer domains between WHMCS and a registrar? Would this even be within the scope of the module? No, this wouldn't work. You could possibly connect multiple accounts at your registrar to a single WHMCS and manage all domains within connected accounts (utilizing renamed registrar modules). The Existing Domains module (by WHMCSServices) is designed for linking existing domains registered within your WHMCS to services. You can reach out to your registrar for details regarding "Domain Trade/PUSH" to your account, which could then be added to WHMCS using their registrar module, and subsequently managed with your Existing Domains module. 1 Quote Link to comment Share on other sites More sharing options...
mddrch Posted January 30, 2024 Author Share Posted January 30, 2024 On 1/27/2024 at 4:12 AM, radwebhosting said: Yes, they should be transferred into your account at the registrar. Different TLDs have different procedures for this, often known as Inter-registrar transfers, domain push, or domain trade. This would be the appropriate selection for when your clients are using any domain that is not managed within your WHMCS. No, this wouldn't work. You could possibly connect multiple accounts at your registrar to a single WHMCS and manage all domains within connected accounts (utilizing renamed registrar modules). The Existing Domains module (by WHMCSServices) is designed for linking existing domains registered within your WHMCS to services. You can reach out to your registrar for details regarding "Domain Trade/PUSH" to your account, which could then be added to WHMCS using their registrar module, and subsequently managed with your Existing Domains module. Thank you for this detailed answer! 0 Quote Link to comment Share on other sites More sharing options...
RadWebHosting Posted February 6, 2024 Share Posted February 6, 2024 On 1/30/2024 at 2:50 AM, mddrch said: Thank you for this detailed answer! Happy to help! 0 Quote Link to comment Share on other sites More sharing options...
