zoe Posted January 8, 2008 Share Posted January 8, 2008 Hi, some clients are having problems to loggin on system. The email /account is created on my WHMCs, but when they try to log, says the user / email doesnt exist... I checked the ip and email to see if its banned, and is not... What can be wrong? 0 Quote Link to comment Share on other sites More sharing options...
railto Posted January 8, 2008 Share Posted January 8, 2008 are they using a free email service like yahoo or hotmail? 0 Quote Link to comment Share on other sites More sharing options...
JofleyUK Posted January 10, 2008 Share Posted January 10, 2008 I would submit a ticket to Matt for this one, I have not come across this one. Even if the banned emails are imported to the database and the user logs on using a free email address they have already created the user will still be able to login as this is only used for validation on the order process. 0 Quote Link to comment Share on other sites More sharing options...
zoe Posted January 16, 2008 Author Share Posted January 16, 2008 Thank you for the suggestion. 0 Quote Link to comment Share on other sites More sharing options...
support@shopwebsecure.com Posted January 17, 2008 Share Posted January 17, 2008 try to use just letters without numbers & symbol as the password 0 Quote Link to comment Share on other sites More sharing options...
dsaunier Posted January 17, 2008 Share Posted January 17, 2008 Could *you* log in as them with their UN and PW from another test machine ? Or they copying / pasting infos ? If not it might be a typo or I mistaken for an L etc, and if they are they should make space an extra whitespace is not copied by mistake. Just my 0.02 0 Quote Link to comment Share on other sites More sharing options...
