Reduce Fraud & Chargebacks With FraudLabs Pro Fraud Prevention Module
fraudlabspro
FraudLabs Pro Fraud Prevention For WHMCS helps online businesses to prevent losses and chargebacks from fraudulent orders. It helps to identify high risk transactions by using its comprehensive and advanced algorithm engines to validate every elements in the fraud screening process, such as IP geolocation, proxy, email, blacklist, credit card, transaction velocity and others to unveil fraud orders accurately. On top of that, FraudLabs Pro SMS Verification acts as a second fraud protection layer by validating the customer’s cellphone number right after the fraud validation. This could be useful as it will help you to confirm if the given phone number is valid and owned by the buyer.
Key Features:
  • Customize your own validation rules. There are more than 50 rules for your selection.
  • Put the high risk orders on hold for your manual review and release.
  • Automatically cancel the order if it is marked as high risk.
  • Automatically email the customer if the order was canceled by the system.
  • Receive notification via email/App/Slack when an order is canceled or pending for your review.
  • Support SMS verification to automate the customer's phone number authentication.
  • Various fraud insight reports for your analysis.
  • Improve conversions with smart fraud checks powered by AI & Machine Learning.
Why FraudLabs Pro?
Flexibility: We offer you a flexible solution to identify a fraudulent order. You can use our FraudLabs Pro score to determine a fraudulent order or customize your own validation rules to target a specific case, or a combination of both.
Free: We are not offering you a trial version, but a free version to start protecting your online business. It’s absolutely free if your monthly orders are less than 500 transactions. There is no upfront credit card information needed, commitment, hidden cost and whatsoever.
Easy to setup: The setup is simple and only takes a few minutes. You just need to install the free FraudLabs Pro plugin, enter the API key and configure the settings.
Trustworthy: We have been in the fraud prevention industry for more than 10 years. Thousands of our clients are currently using our FraudLabs Pro solution. . Please check out our website https://www.fraudlabspro.com for details.
  • 1 month later...
  • 7 months later...
