HostingClean Posted February 7, 2021 Share Posted February 7, 2021 Actions Login to cPanel Login to Webmail Change Password Request Cancellation I would like to move this menu from the sidebar and put it in the body on the clientcart. Where to find the code to do this change. It will be in the same page. domain.com/clientarea.php?action=productdetails&id=1 Thanks in advance 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted February 7, 2021 Share Posted February 7, 2021 15 hours ago, HostingClean said: I would like to move this menu from the sidebar and put it in the body on the clientcart. as a sidebar within the page, or as separate normal links.... either way, you'd have to create it in the clientareaproductdetails template (or possibly with a hook - though template edit might be easier). the point being that the code can't be "moved" - you would have to sidebar the sidebar and recreate it from scratch in the template. 0 Quote Link to comment Share on other sites More sharing options...
