Emretorx Posted October 6, 2020 Share Posted October 6, 2020 Hi i have a question i want to localize the whois extension which is whois for client but i coulnt find any documentation about it i wonder community can help me best regards. 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted October 22, 2020 Share Posted October 22, 2020 On 06/10/2020 at 12:52, Emretorx said: Hi i have a question i want to localize the whois extension which is whois for client but i coulnt find any documentation about it i wonder community can help me do you mean you want to show whois info to a client when they make a search ? https://marketplace.whmcs.com/product/4795-whois-for-clients 1 Quote Link to comment Share on other sites More sharing options...
Emretorx Posted October 26, 2020 Author Share Posted October 26, 2020 On 22.10.2020 at 19:03, brian! said: Arama yapan bir müşteriye whois bilgilerini göstermek istediğini mi söylüyorsun? https://marketplace.whmcs.com/product/4795-whois-for-clients I installed this module. but the outputs are in english how can i translate this into another language 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted October 27, 2020 Share Posted October 27, 2020 On 26/10/2020 at 07:56, Emretorx said: I installed this module. but the outputs are in english how can i translate this into another language the modules not encrypted, so you should just need to edit the "clientArea.tpl" file in the module's own /templates directory. and change the text in the lines i've added *** to... <div class="row"> <div class="col-lg-12 col-lg-offset-3"> <form method="POST" action="{$moduleLink}" class="form-inline" > <div class="col-lg-12 align-content-center"> <div class="input-group col-lg-8"> <input type="text" class="form-control input-lg" placeholder="example.com" name="domainName" value="{$domainName}" /> <span class="input-group-btn"> <button class="btn btn-primary btn-lg" type="submit" > ***GET WHOIS*** </button> </span> </div> </div> </form> </div> </div> <br> <br> <div class="row"> {if !empty($whoisData) } <div class="panel panel-primary"> <div class="panel-heading">***WHOIS Data for <strong>{$domainName}***</strong></div> <br> <div class="row"> <div class="col-lg-10 col-md-offset-1"> <div class="alert alert-warning" role="alert"> <span class="glyphicon glyphicon-info-sign" aria-hidden="true"></span> <span style="font-size:14px">***This domain name is {$whoisData['status']}***</span> </div> </div> </div> <div class="panel-body"> {$whoisData['whois']} </div> </div> {/if} </div> 1 Quote Link to comment Share on other sites More sharing options...
Emretorx Posted October 28, 2020 Author Share Posted October 28, 2020 16 hours ago, brian! said: modüller şifrelenmemiştir, bu nedenle modülün kendi / templates dizinindeki "clientArea.tpl" dosyasını düzenlemeniz yeterlidir. ve *** eklediğim satırlardaki metni değiştirin ... THNKS Brian, I know you are a genius I know this but https://prnt.sc/v8h80f How can I translate the fields I have drawn in red into another language. Such as "Unavailable", "Created on" 0 Quote Link to comment Share on other sites More sharing options...
brian! Posted October 29, 2020 Share Posted October 29, 2020 On 28/10/2020 at 08:34, Emretorx said: How can I translate the fields I have drawn in red into another language. you should be able to translate the unavailable / available text by changing (in clientArea.tpl)... <span style="font-size:14px">bu alan {$whoisData['status']}</span> to... <span style="font-size:14px">bu alan {lang key="whois.`$whoisData['status']`" defaultValue=$whoisData['status']}</span> and then you'll need to add the last two lines below Language Overrides to an /overrides/turkish.php file (forgive the Turkish translations if they're wrong!).. <?php $_LANG['whois']['unavailable'] = "kullanılamıyor"; $_LANG['whois']['available'] = "kullanılabilir"; with regards to the whois output (the larger red box), the API function used is just returning the complete output it receives from the whois server - it would be a pain to translate it because every whois server gives a slightly different output, which could change at any time... 1 Quote Link to comment Share on other sites More sharing options...
Emretorx Posted October 30, 2020 Author Share Posted October 30, 2020 thanks brian 0 Quote Link to comment Share on other sites More sharing options...
