Double Click to Process Order
SpringNodes
Hi Calum,
20 hours ago, SpringNodes said:
As you can see in the video below, it takes two clicks to actually process the order. How could I fix this?
it's probably worth noting that the Modern orderform was deprecated many years ago - it's still shipped, but hasn't really been updated in years and I doubt that it will be included in v8 releases.
I would suggest switching to Standard Cart and then seeing if the same issue occurs.
