Cloning "My Products & Services" page issue
I am having some issues with making a clone of the "My Products & Services" (clientarea.php?action=services) page.
I have created a orderstatus.php & orderstatus.tpl page with what seems like the working/correct details but the table shows as blank? Im sure it is an easy to fix thing but  I cannot get my head around it!
Here is the two files I am using:
orderstatus.php:
<?php
 define("CLIENTAREA",true);
 //define("FORCESSL",true); // Uncomment to force the page to use https://
 require("init.php");
 $ca = new WHMCS_ClientArea();
 $ca->setPageTitle("Your Order Status");
 $ca->requireLogin(); // Uncomment this line to require a login to access this page
 $ca->initPage();
 //$ca->requireLogin(); // Uncomment this line to require a login to access this page
 # To assign variables to the template system use the following syntax.
 # These can then be referenced using {$variablename} in the template.
 $ca->assign('variablename', $value);
 # Define the template filename to be used without the .tpl extension
 $ca->setTemplate('orderstatus');
 $ca->output();
orderstatus.tpl page:
{include file="$template/includes/tablelist.tpl" tableName="ServicesList" filterColumn="4" noSortColumns="0"}
<script type="text/javascript">
    jQuery(document).ready( function ()
        var table = jQuery('#tableServicesList').removeClass('hidden').DataTable();
        {if $orderby == 'product'}
            table.order([1, '{$sort}'], [4, 'asc']);
        {elseif $orderby == 'amount' || $orderby == 'billingcycle'}
            table.order(2, '{$sort}');
        {elseif $orderby == 'nextduedate'}
            table.order(3, '{$sort}');
        {elseif $orderby == 'domainstatus'}
            table.order(4, '{$sort}');
        {/if}
        table.draw();
        jQuery('#tableLoading').addClass('hidden');
</script>
<div class="table-container clearfix">
    <table id="tableServicesList" class="table table-list hidden">
        <thead>
            <tr>
				<th></th>
                <th class="text-left">{$LANG.orderproduct}</th>
                <th>{$LANG.clientareaaddonpricing}</th>
                <th>{$LANG.clientareahostingnextduedate}</th>
                <th>{$LANG.clientareastatus}</th>
                <th class="responsive-edit-button" style="display: none;"></th>
            </tr>
        </thead>
        <tbody>
            {foreach key=num item=service from=$services}
                <tr onclick="clickableSafeRedirect(event, 'clientarea.php?action=productdetails&amp;id={$service.id}', false)">
					<td class="text-center{if $service.sslStatus} ssl-info{/if}" data-element-id="{$service.id}" data-type="service"{if $service.domain} data-domain="{$service.domain}"{/if}>
                            <img src="{$service.sslStatus->getImagePath()}" data-toggle="tooltip" title="{$service.sslStatus->getTooltipContent()}" class="{$service.sslStatus->getClass()}"/>
                        {elseif !$service.isActive}
                            <img src="{$BASE_PATH_IMG}/ssl/ssl-inactive-domain.png" data-toggle="tooltip" title="{lang key='sslState.sslInactiveService'}">
                        {/if}
                    </td>
                    <td><strong>{$service.product}</strong>{if $service.domain}<br /><a href="http://{$service.domain}" target="_blank">{$service.domain}</a>{/if}</td>
                    <td class="text-center" data-order="{$service.amountnum}">{$service.amount}<br />{$service.billingcycle}</td>
                    <td class="text-center"><span class="hidden">{$service.normalisedNextDueDate}</span>{$service.nextduedate}</td>
                    <td class="text-center"><span class="label status status-{$service.status|strtolower}">{$service.statustext}</span></td>
                    <td class="responsive-edit-button" style="display: none;">
                        <a href="clientarea.php?action=productdetails&amp;id={$service.id}" class="btn btn-block btn-info">
                            {$LANG.manageproduct}
                        </a>
                    </td>
                </tr>
            {/foreach}
        </tbody>
    </table>
    <div class="text-center" id="tableLoading">
        <p><i class="fas fa-spinner fa-spin"></i> {$LANG.loading}</p>
    </div>
</div>
All I need the orderstatus.php page to show is the details as the default page, then I can work with changing it from there.
Hopefully, someone can help me!
Thank you :)
you will need to query the database to get this client's services... normally, you would do that in a hook, but as it's a custom.php file, you can do it in there instead.
https://developers.whmcs.com/advanced/db-interaction/
oh that's all? 🙂
oh that's all? 🙂
I have added it in:
<?php
 use WHMCS\Database\Capsule;
 $ca->initPage();
 $ca->output();
But it still doesn't work? I'm definitely doing something wrong ;/
