Order Accept Encountered Problems
possibly you have the "Block Existing Domains" option enabled in general settings -> ordering....
https://docs.whmcs.com/Ordering_Tab#Block_Existing_Domains
Quote
Enabling prevents visitors mistakenly or maliciously ordering a new product with a domain name that is already pending, active or suspended in your system.
that error message is saying that there is already an order using that domain in your database.
  • 1 year later...
Hello, I tried the two solutions above. But I still get the error.
Error comes about when I'm accepting a new order.  Says Running Module Create on Accept Pending Order then Module Create Failed - Service ID: 106 - Error: (XID dqt7t8) The domain “example.com” already exists in the userdata.
This is the what I get on the activity logs.
The domain registration is sent t the registrar and the cpanel account is setup but the order remains as pending. I then have to manually approve the cpanel service as active then accept the order.
Could I get some assistance?
