smarty problems after upgrading
WizTech
I went to support immediately when this happened because it's a repeat of earlier this year. I have a branded six template with few custom changes. The first time it was determined that the template had stored something in the database that upgrading doesn't change and support was able to tell me exactly where to look. This time they brushed me off twice and told me to switch to the default six instead. Uh, folks, branding is important and I have no desire to totally redo the whole thing - messaging and all.  Last March I pushed all six files to my custom template which did not fix that problem.  So how in the h... do I figure out where the problem is? The php error is
Error: Call to a member function count() on null in /home/venturz/templates_c/461a4f0b9784adbd968506a18ac384135df7980e_0.file.viewcart.tpl.php:1098
Stack trace:
#0 /home/xxxxxx/public_html/hosting/vendor/smarty/smarty/libs/sysplugins/smarty_template_resource_base.php(123): content_5d6962c4639995_38520545(Object(Smarty_Internal_Template))
#1 /home/xxxxxx/public_html/hosting/vendor/smarty/smarty/libs/sysplugins/smarty_template_compiled.php(114): Smarty_Template_Resource_Base->getRenderedTemplateCode(Object(Smarty_Internal_Template))
#2 /home/xxxxx/public_html/hosting/vendor/smarty/smarty/libs/sysplugins/smarty_internal_template.php(216): Smarty_Template_Compiled->render(Object(Smarty_Internal_Template))
#3 /home/xxxxx/public_html/hosting/vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(232): Smarty_Internal_Template->render(false, 0)
#4 /home/xxxxx/public_html/hosting/vendor/smarty/smarty/libs/sysplugins/smarty_internal_templatebase.php(116): Smarty_Internal_TemplateBase->_execute(Object(Smarty_Internal_Template), NULL, NULL, NULL, 0)
#5 /home/xxxxx/public_html/hosting/vendor/whmcs/whmcs-foundation/lib/Smarty.php(0): Smarty_Internal_TemplateBase->fetch('/home/venturz/p...', NULL, NULL, NULL, false, true, false)
#6 /home/xxxxx/public_html/hosting/includes/clientareafunctions.php(0): WHMCS\Smarty->fetch('/home/venturz/p...')
#7 /home/xxxxx/public_html/hosting/cart.php(0): outputClientArea('viewcart', false, Array)
#8 {main}
Does this mean that the viewcart.tpl.php  is the issue?
what did Support tell you to do the first time?
how much customisation have to you do the templates? and are all the changes in the template, or are there hooks involved as well ??
24 minutes ago, WizTech said:
So how in the h... do I figure out where the problem is? Does this mean that the viewcart.tpl.php  is the issue?
looking at your site, it fails with Modern (and generates the above error when using your theme or Six), but works fine with Standard Cart (and your theme)...
two thoughts...
  1. which version of WHMCS is this - v7.8 or v7.8.1 ? I know v7.8.1 mentions the following in the changelogs..
    Quote
    CORE-13681 - Prevent error for undefined variable in Boxes & Modern carts
    so if you're on v7.8, upgrading to v7.8.1 might fix this (if it's the same error).
  2. in Modern, it seemingly crashes at viewcart, but using SC, it goes to configuredomains first and not straight to viewcart... i'm not seeing any obvious differences between your Modern viewcart template and the clean version of the template.
you probably already know this, but Modern was deprecated years ago and doesn't really get updated - the odd tweak to make sure it basically works, but new features available in SC aren't added to Modern... so at some point, you're going to have to switch to standard_cart (or one of the other newer options) as Modern won't continue to work indefinitely.
Thanks for the explanation. I really prefer the Modern for my business and in fact have just given up my server. I use this as my primary invoicing program for my all clients. The hosting was always a small amount of this. Just managed to wipe out my saved correct password for whmcs so got to get back in to go further. Thanks so very much for your complete answer!
I did just upgrade to 7.8 as prompted. Now I see other problems. I have always hated WHCMS for the upgrades and now the easier one-click ones are still a problem. Way too much work but kinda stuck in it now.
